eznpc Why Hand of Naz Farming Matters in Diablo 4
EmberPhoenix
Hand of Naz is one of those drops you don't think about until your build starts stalling, then suddenly it's all you can think about. If you're trying to push higher tiers and your damage or survivability feels like it's missing a piece, that's usually the moment the chase begins. The boring truth is you need access to the right loot tables, and that means moving up in World Tiers; if you're also trying to keep your runs efficient, plenty of players pair their grind with simple boosts like cheapest Diablo 4 Gold so they can reroll stats and keep pace without wasting whole evenings.
Get Your Tier Right
World Tier 3 is the minimum where farming starts to feel real, but World Tier 4 is where the drops finally match the effort. The jump can be rude, though. If you go in undergeared, you'll spend more time running back than killing. Tighten your armor, sort your resists, and make sure your build isn't held together by one cooldown. You don't need perfection, but you do need consistency, because the whole point is more clears per hour, not heroic wipes that look cool and do nothing for your stash.
Nightmare Dungeons That Respect Your Time
Nightmare Dungeons are still the backbone of the grind, but not all of them are worth your energy. Pick a small set you can run on autopilot. Skip the ones with drawn-out objectives or awkward backtracking. What you're hunting for is elite density and clean routes. It's fine to leave a few stray mobs alive; you're not here to vacuum the floor. Burn down elite packs, keep moving, and don't be afraid to salvage and reset fast. The faster your loop, the more chances you roll at the end of the run.
Helltides, Boss Timers, and Quick Swaps
When dungeons start to blur together, swap to Helltides and treat them like a focused shopping trip. Farm Cinders, open the Tortured Gift chests that match what you actually need, and don't get greedy and die with a pile in your pocket. World Bosses are also a solid detour: show up, land your damage, grab the loot, leave. It's a nice rhythm break, and sometimes that one quick kill feels better than an hour of identical corridors.
Group Up When You Want More Rolls
If you can handle it, group rotations are the easiest way to crank up loot per hour, because everything dies quicker and the pace stays honest. Just don't join a squad and then spend half the run waiting on resources; tune your setup so you're always doing something. And if you're short on materials, rerolls, or you simply want to smooth out the grind, a lot of players use eznpc to pick up game currency or items so they can keep farming instead of stopping to scrape together upgrades mid-session.
