Chevrole TS - 00 Security problem
NickW
Halloj!
Nu är man ytterligare ett problem. Har nu bytt Oljekylare, topplock. Bilen vägrar starta nu. Den bara tickar och står security I info rutan. Batteriet var dött och försökte med startkablar. Hjälpte ej. Prövat med nycklen I run i 10min. Hjälpte ej. Är det bara att kasta bilen nu när något vram är fel i huvud datorn? Prövat med flera nycklar. I innan jag bytade oljekylare funkade den.
~W
Re: Chevrole TS - 00 Security problem
Det låter som att den antingen inte kan kommunicera med transpondern i nyckeln eller har tappat bort den. Prova att få in den i systemet igen med denna metod:
30 Minute Relearn Procedure (Steps): This is for a "replacement" (new) key (no original available)
1) Insert a "Master" Passkey III (PK3) Key (the one with the black plastic cover as shown above).
2) Turn the Ignition to ON, but do NOT start the engine. You should see the "Security" message on the dash for about 10 minutes and then it will turn off.
3) Turn OFF the Ignition and wait 5 seconds.
4) Repeat the above steps (1-3) a total of 3 times, or a total of 30 minutes.
5) After the third time (including turning back to the OFF position), start the van. The van should now have "learned" the transponder information and will allow it to start and continue to run.
Important Notes:
- When the above procedure is used, all previously learned keys will be erased from system memory.
- Additional keys can be learned immediately after the relearn procedure. This is done by inserting the additional key and turning the ignition to the RUN position within 10 seconds of removing the previously learned key
Procedure to add a "duplicate" key (have original)
1) Insert the "Original" (working) Key.
2) Turn the Ignition to ON (RUN), but do NOT start the engine. Turn the Ignition OFF and remove the key.
3) Within 10 seconds insert the new "duplicate" key and turn the Ignition to the ON position. The Security indicator should light for about 2 seconds to indicate that the new key has been programmed.
4) The new key should now be able to start and run the van.
