How to Drive the Ferrari J50 in Forza Horizon 6 – Unlock Tips and Tricks
FrostStrikeX
Forza Horizon 6 is gearing up to launch with some amazing cars, and one of the most exciting vehicles available is the 2017 Ferrari J50. This iconic car can be unlocked through a time-limited pre-order bonus or by purchasing it in the in-game Autoshow. Whether you're an early bird or someone who prefers to grind for the car later, here’s everything you need to know about unlocking and driving the Ferrari J50 in Forza Horizon 6.
How to Unlock the Ferrari J50
There are two main ways to get your hands on the Ferrari J50 in Forza Horizon 6:
1. Pre-Order Bonus (Pre-Tuned Edition)
To secure the Ferrari J50 before the official release on May 19, 2026, you need to pre-order any edition of the game (Standard, Deluxe, or Premium) or the Premium Upgrade before launch. The pre-order version is a pre-tuned Ferrari J50, giving you an edge right from the start with higher performance stats, allowing you to dominate early-game events. This is a limited-time offer, so make sure to lock it in before the game drops!
2. Standard Edition (Autoshow)
If you missed the pre-order window, don’t worry—the standard 2017 Ferrari J50 will be available for purchase in the in-game Autoshow using credits. This version doesn’t come pre-tuned, but it still packs plenty of power and precision for your racing needs.
Quick Tips and Performance Tricks for Driving the Ferrari J50
Once you’ve unlocked the Ferrari J50, here are some tips to make the most of its performance on the roads and tracks of Forza Horizon 6.
Optimal Handling
The Ferrari J50 features a mid-engine, rear-wheel-drive setup, giving it excellent grip and balance. This car excels in stability, especially during uphill and downhill sprints. It’s perfect for tight cornering, and with the right upgrades, you’ll be able to take on any of Japan’s winding mountain roads with ease.
Tip: To make the most of the handling, keep your gear shifts quick and smooth. This car is known for its fast transmission, and maximizing that performance will make you a beast on the track.
Aerodynamic Advantage
The J50 is built with low-placed carbon fiber air intakes and a specialized cooling system to improve its aerodynamics. This feature makes the car more resistant to drag, allowing for faster speeds and greater cornering efficiency.
Tip: Focus on upgrades that improve downforce. These will boost your cornering speeds, especially on the narrow, twisty roads of Japan’s urban and mountain environments.
Drifting Potential
While the Ferrari J50 is built with a focus on precision handling and speed, you can also transform it into a solid drift car. With the right tuning, like adding Drift Suspension and a Drift Tire Compound, you can push the J50’s horsepower to nearly 1,400. However, because it's a rear-wheel-drive car, throttle control is key to maintaining smooth drifts.
Tip: Work on your throttle management when drifting, especially in high-speed situations. The J50 can get loose if you push it too hard, so finding the balance between power and control is crucial.
Campaign Usage
If you're planning to use your Ferrari J50 in the main campaign, there’s a progression system to keep in mind. First, you’ll need to go through the Horizon Qualifiers to earn your initial wristbands. This is required to unlock faster car types and participate in higher-tier events.
Tip: Don’t rush through the campaign—take your time to accumulate wristbands and improve your overall car collection. Once you unlock the right wristband tiers, the Ferrari J50 will shine even brighter in tougher challenges.
Driving the Ferrari J50 in Forza Horizon 6 is an exhilarating experience. Whether you’re enjoying the pre-tuned bonus car at launch or working your way to it in the Autoshow, this car will definitely stand out with its excellent handling, aerodynamic design, and high performance. By focusing on optimal handling, upgrades for downforce, and mastering drifting, you’ll be able to fully experience the Ferrari J50's power on the stunning roads of Japan.
